General Automotive Discussion
a/c blower motor keeps running
Old Oct 11, 2004 | 10:13 AM
aharrell's Avatar
aharrell
I need some help on a non-ford related topic. If this is the correct forum, let her rip!
I have a '94 Olds Regency 98, and I was driving it home yesterday and the blower motor would stay on even when I cut the a/c off, and then when I turned the ignition key off and even got out of the car. When I got home I pulled the A/C fuse to get the blower motor to stop. Then, I systematically pulled a relay, plugged the a/c fuse back in, blower motor came back on......pull a/c fuse again, replace relay, pull next relay, plug a/c fuse back in, blower motor comes back on, repeat process until all relays have been pulled. I managed to troubleshoot each relay that I could find, which were a total of 5 or 6 right on the firewall, basically. I just had to pull the a/c fuse and leave it out for now.
Has anyone ever had this happen? Any help would be appreciated. Thanks!
Old Oct 11, 2004 | 01:26 PM
Mike W's Avatar
Mike W
If it is not a relay, I would check the blower switch.
Old Oct 11, 2004 | 01:34 PM
aharrell's Avatar
aharrell
dang....I can probably figure it out on the Ford Truck but I'm not as good on this Oldsmobile. I'm going to get a manual this afternoon from a friend on the Buick Park Avenue (very similiar).
The blower switch....would it be in the controls or where would it be?
Old Oct 11, 2004 | 02:49 PM
Mike W's Avatar
Mike W
That would be the switch you turn to change the speed of the blower. I would think it would be more apt to go open instead of short circuiting. A diagram would make it easy to fix.
Old Oct 11, 2004 | 02:59 PM
aharrell's Avatar
aharrell
ok...makes sense. You can change the speed of the fan to your desire, you can make the air cooler or warmer, but when you turn it off, it just keeps blowing and changes to the vents where defrosting would occur.
Maybe this manual will reveal a little more.
thanks!
Old Oct 11, 2004 | 03:21 PM
Mike W's Avatar
Mike W
It sounds like the switch is ok. I am just too used to the older ones that had an off position on the switch. You need to find out how the switch gets +12.
BVA
Apr 3, 2022 11:04 AM
Usaman
Nov 10, 2016 09:31 AM
jtcdudeman
Sep 16, 2016 01:05 PM
econolinemanor
Aug 24, 2015 05:12 PM
Chuck Fuller
Mar 26, 2015 04:47 PM
