Bronco II Ford Bronco II
tranny
Old Jan 25, 2000 | 10:02 PM
jesses's Avatar
jesses
tranny
I have an 88 bronco II 4x4 with the mitsubishi 5 spd. manual transmission. I was wondering if any one could tell me what's the proper lube to fill it with? I've been told gear oil, atf and a mixture of both. I'm using gear oil right now and it sure doesn't like the cold. Thanks
Old Jul 7, 2000 | 05:11 PM
markmc's Avatar
markmc
tranny
The proper lube is Ford Part No. F2ZZ19C547-A it is a synthetic lube.
Old Sep 7, 2000 | 12:30 PM
jb85302's Avatar
jb85302
tranny
I had the same tranny and it went bad (real bad). The rebuild shop told me to use 15w40 engine oil. I asked if 15w50 Synthetic Castrol would be o.k. He said that would be even better. If you do run engine oil you have to change it a little more often. I put 30,000 miles on mine before I sold it and it still worked fine. Yes,gear oil makes them shift pretty stiff in the winter.
Old Sep 7, 2000 | 06:33 PM
tbird6391's Avatar
tbird6391
tranny
[font size="1" color="#FF0000"]LAST EDITED ON 07-Sep-00 AT 07:38 PM (EST)[/font][p]Please be careful in getting the proper lubricants.
According to the Ford factory shop manual for my 90 Bronco II, the proper lubricants are:
Mitsubishi 4sp: SAE 80w-85, (Ford p/n D 8 DZ-19C547-A, Ford spec ESP-M2C83-C).
Mazda 5sp: Mercon ATF, (Ford p/n XT-2-QDX, Ford spec: Mercon).
I don't believe they used a Mitsubishi 5sp, at least not in 90 & later. My 91 Tbird SC has the Mazda 5sp in it, same as the little trucks.
Old Sep 8, 2000 | 10:35 AM
hoppy's Avatar
hoppy
tranny
Jermafenser
Oil & Lubrication
Dec 22, 2014 01:01 PM
Tom Callan
Mar 4, 2014 10:03 AM
95350PS
May 18, 2012 05:57 PM
5504x4drwcrew
Nov 2, 2011 07:12 PM
870
15
Apr 17, 2007 07:03 PM
