Bronco II Ford Bronco II
Flakey Oil Pressure
Old Sep 7, 2000 | 07:47 PM
tbird6391's Avatar
tbird6391
Flakey Oil Pressure
[font size="1" color="#FF0000"]LAST EDITED ON 07-Sep-00 AT 08:48 PM (EST)[/font][p]I have heard that the 2.9L may have problematic oil pumps. Could someone confirm this?
Reason I ask is that the gage drops a little sometimes, mostly in colder weather. Goes up some in warmer weather. Now it's getting cooler around here, and the gage is lower than ever before. This flies in the face of worn bearings etc. which would react oppositely to temperature.
I suspect the sender, only I would like a little feedback before I go through the hassle of chasing down a problem with the gage or the sender.
Obviously, I dont want to drive it any if the "oil pump rumor" can be verified. Hate the thought of that job :-/
Thanks,
Rick
Old Sep 7, 2000 | 08:21 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Flakey Oil Pressure
Tbird, Haven't heard about bad oil pumps on 2.9, but before you buy a new sender, try cleaning terminal and wiping a little dielectric grease on it. May be corroded (or loose) and giving a false resistance reading. Don
"Nothing lasts forever except natural stone and old Ford trucks." (Willie Nelson)
Old Sep 7, 2000 | 09:03 PM
Avanti's Avatar
Avanti
Flakey Oil Pressure
I agree with cleaning the sending unit. They get crud on the inside & tend to stick. I had it happen on a new engine where the unit was reading lower than it should. Cleaned it and it works better. I have even had new sending units act crazy after 6 months of use.A direct pressure reading unit would have been much better.
89 Bronco II
92 F-150
93 Aerostar
74 Maverick
64 Avanti
Old Sep 9, 2000 | 08:43 PM
cbadgerjr's Avatar
cbadgerjr
Flakey Oil Pressure
Had a similar problem with my B-II, turned out the plug connector to the oil pressure sending unit was loose. Sometimes it would make good contact, sometimes it wouldn't. Drove me crazy till I found the culprit connection.
>temperature.
>the sender.
>it any if the "oil
>job :-/
>Thanks,
>Rick
Old Sep 19, 2000 | 02:24 PM
berso's Avatar
berso
Flakey Oil Pressure
Janickfa
16
Oct 3, 2019 08:36 AM
fordopie
Mar 29, 2012 09:08 AM
Gage2502
Jul 10, 2008 03:30 PM
mich52
Dec 30, 2003 12:47 PM
John W Cina
Aug 29, 2003 01:02 PM
