Just Another Vin Decode Please...
Old Oct 10, 2004 | 08:37 PM
FOMOCO1965's Avatar
FOMOCO1965
Question Just Another Vin Decode Please...
Hi Everyone, I Know This Is Another Vin Question But I Am New Here, So I Was Wondering If Someone Could Tell Me The Information On My Vin Plate On My 1965 F-100 Stepside. It Reads.
F10dk703444
Wb-115
Color-t
Body-d81
Trans-g
Axle-a8
Dso-511474
Any Information Would Be Great..thanks..
Old Oct 10, 2004 | 10:17 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
What is it? a little help
FOMOCO1965, the answer is NO! Just kidding, WB is the wheel base in inches, Color, i'm lost, body, i'm still lost as well as axle. Trans, C-4, DSO is the district that the vehicle was delivered and any special ordered factory items installed. A little help with the puzzle, maybe someone else on this form will save us. Carl.............o&o>...........
Old Oct 11, 2004 | 09:15 AM
Mike G's Avatar
Mike G
FOMO- First off, welcome aboard here!
Secondly, here are more specifics to your VIN that are associated to the model year you have:
F10=f100 4x2
d=352 V8
k=Kansas City assembly
703444=June 1965 build
Wb=Wheel base 115 inches
Color T=Sandshell Beige
Body D81= sorry can't figure that one..
Trans G=Crius-o-matic (no C4 auto's behind a FE engine)
Axle A8= 3.54:1 ratio
DSO are dealer options, someone here has all those code numbers
If you wish to have a look a look for future reference: http://www.home.earthlink.net/~jcpurut/vin/vin.html
Enjoy --Mike
Old Oct 11, 2004 | 12:52 PM
RaleighDad66's Avatar
RaleighDad66
From what I can tell D81 is Beige Woven Plastic and Beige Vinyl w/Foam Cushion (for the D Trim Scheme) and Conventional Cab (for the 81)
Old Oct 11, 2004 | 03:44 PM
wizzard351's Avatar
wizzard351
hey mike thanks had to print that for future use.just wanderin if the origanal warrenty tag is gone and nowhere to be found how can you tell what they come when new such as trans,colour,bobycode ect.??
Old Oct 11, 2004 | 04:28 PM
Mike G's Avatar
Mike G
The VIN numbers are also stamped into the top of the frame on the passenger side between the front wheel and the radiator support. This can also be found under the cab too but that requires a little more work of course the other items like gearing and DSO codes are a little tougher to figure out, the rest is relatively easy after you have looked at or seen 20-30 of these trucks...
--Mike
