where to mount cb antenna
i am going to put a cb in my 93 and was wondering wheresome of you may have mounted a cb antenna. i thought about mounting it to the spare tire rack' but then where would i run the coax in? i have saw some pickups with it mounted on front fender with a bracket inside hood but haven't been able to find one. what do you all think?
I actually have one of the ones that mount on the glass and love it. My cable is routed to the passenger side rear part of the window and then the antenna sticks to the outside of the window opposite the cable. I've had it like this for over 5 years and still holding and working great.
Good luck,
Good luck,
Best location for CB coverage is center top of Cab Roof. K40 antenna (one of the best) works great in this location, good ground plain. and also has quick turn release so you can remove it. One of the worst types of antenna to run is the dual trucker antenna, makes you very directional, forward and rearward. Nessary for Big rigs because the rig would block the signal to one side, thus the need for another antenna on the other side. A proper CD antanna should be 102" long to get the proper wave length but that isn'r pratical for most, so whips are cuy shorter with a coil load added, the coil load helps fool the CB to think it has the proper length antenna or SWR, so the shorter the antenna the larger the coil load the weaker the signal. And always tune your antenna with an SWR meter.
So if you want really good coverage try the K40, its an amazing antenna. Check out K40.com for more info.
Taking a hint from my "office," I'd agree that the roof is the best place. The least amount of interference from anything is up there. That's why we mount aircraft antennea on the top and bottom, rather than the sides.
Just make sure that you seal the hole in the roof. The '93 I just bought has an antenna up there ... and it leaks into my dome light. Gonna have to fix that ASAP.
or trees.....i have my cb antenna mounted on a 6 inch square of aluminum sheet, screwed to the tire rack, i get great reception, and it dosnt get knocked off when i go 4 wheeling. BUT...my scanner antenna is a mag-mount on the roof, and i hafta take it down to go in the woods....or the car wash. i would say the tire rack is the best place
