The frontends are different (but the front brakes are not)
,snip>
tailgate shells are the same, rear windows are different
engines offered do have some overlap.
And the tailgate still has the same problems with latches seizing up, skin rusting out, window motor plastic bushings turning to powder...
P/S pump is the same, the transfer case is totally different.
Radiator is totally different.
Climate control is completely different.
Frame, body-mounts, etc, are totally different.
But I've got the muffler and twin tailpipes from an '86 351W Bronco on my '78 with a 400, and it works fine.
