Sponsored by: Auxito
code 1504
Old Oct 10, 2004 | 03:58 PM
birdmanoftampa's Avatar
birdmanoftampa
code 1504
i have a 97 ford f150 4x4 4.6 i have scaned the computer and found a code of p1504 does anyone know what this means.
Old Oct 10, 2004 | 04:33 PM
87 XLT's Avatar
87 XLT
P-1504 is "idle air control circuit malfunction" Take a look at the "Read first IAC repair help" at the top of the Explorer forum.
Old Oct 10, 2004 | 06:39 PM
birdmanoftampa
i have changed the iac valve and i still have the problem. i was told that code 1504 was the iat sensor Intake air temperature sensor it runs rough and i am getting alot of black soot on the plugs it also has no power.
Old Oct 10, 2004 | 09:11 PM
87 XLT's Avatar
87 XLT
Sounds like an open in the wiring to the IAC. If i remember correctly that link at the explorer forum will tell you how to test the wiring also.
Old Oct 11, 2004 | 12:34 AM
87 XLT's Avatar
87 XLT
The P-1504 only affects the idle. If this was my truck, i'd pull the codes again & check the fuel pressure. If it runs better at wide open throttle, it might be a bad O-2 sensor.
HAMS64
Aug 15, 2019 12:12 PM
jo97F1504x4
1997 - 2003 F150
Sep 28, 2018 10:49 PM
Hypemansam
Aug 27, 2015 07:19 PM
ctruf1504x4
Apr 4, 2011 12:00 PM
tstorm
Mar 20, 2011 11:07 AM
