What engine do i have
Old Oct 10, 2004 | 03:00 PM
lestenson's Avatar
lestenson
Post What engine do i have
I bought this truck about a week ago today and the guy had put a different engine in it than stock. now i dont know exactly what year and model it came from. all i know is it is a 400, possibly from a LTD crown victoria?
Does it say the model on the engine somewhere?
It is in a 79' F150 Ranger lariat now if that matters
Old Oct 10, 2004 | 03:09 PM
Lane Dexter's Avatar
Lane Dexter
Is there a small metal tag under the bolt that holds the distributor?
There was supposed to be one on the engine in my '77 F250 (VIN decoder says originally 351M). Unfortunately, whoever swapped from the original two barrel intake manifold to the present Edelbrock Performer 400, seems to have lost the tag when moving the coil to the new manifold. In my case, I'm pretty certain it's a 351M or a 400. If I get really curious, I'll pull a plug and measure the stroke (3½ for 351 and 4 for 400).
Go find REAL FORD GUY and let him look under your hood and display his expertise.
Old Oct 10, 2004 | 03:12 PM
lestenson's Avatar
lestenson
but would i be able to find out the model (LTD,crownvicoria....) and the year because i know its a 400 for shure
Old Oct 10, 2004 | 03:19 PM
Lane Dexter
Oh crap, my brain fell out again! I hate it when that happens. Is the DONOR vehicle still available? Can the guy you got this truck from point it out to you? Can you run THAT VIN# through the decoder?
Of course, just identifying the donor vehicle will allow you to check on what engines were available for that car in that year. I recall driving a friend's big mid 70's Ford wagon, and it had a 400 in it. But Ford made a LOT of engines, with a lot of differences (I'm thinking of three 351 engines, for example). Knowing the exact car that supplied the engine would be a big help.
Old Oct 10, 2004 | 03:24 PM
lestenson's Avatar
lestenson
Thanks ill find that out today.
Old Oct 10, 2004 | 03:55 PM
lestenson's Avatar
lestenson
the vin number on the engine thats in the truck right now
Old Oct 10, 2004 | 04:15 PM
lestenson's Avatar
lestenson
this is what i found on my engine i dont know whether this is a vin number or not though but heres what i found. ( some symbol before it) 13726548
Old Oct 10, 2004 | 04:18 PM
lestenson's Avatar
lestenson
if not where do i find it?
Old Oct 10, 2004 | 04:50 PM
73effie's Avatar
73effie
13726548 is the firing order. that is also the firing order of a 351 windsor, if that helps.
Old Oct 10, 2004 | 04:52 PM
lestenson's Avatar
lestenson
could that still be wrong because it says its a 400, dont 351's and 400's use some of the same parts
Old Oct 10, 2004 | 04:55 PM
Lane Dexter
The VIN plate is on the edge of the driver's door on my 1977. Just open the driver's door. On most newer automobiles, it's on a plate on top of the dash on the driver's side, visible from outside the car.
Here's the URL for the VIN decoder:
http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi
Old Oct 10, 2004 | 04:58 PM
lestenson's Avatar
lestenson
that one is all messed up. but still it wouldn't tell me what kind of engine it is because my engine is from a unknowen donor. isn't there a vin number on the engine somewhere
Old Oct 10, 2004 | 05:04 PM
pops_91710's Avatar
pops_91710
nope, no vin numbers are put on an engine. VIN stands for Vehicle Identification NUmber. The engine is not a vehicle, therefore to put a vin tag on it would be useless.
Go here for all the information you'll ever be able to use on the 400: http://home.earthlink.net/~bubbaf250/index.html
Old Oct 10, 2004 | 06:49 PM
Mil1ion's Avatar
Mil1ion
Engine Ident.
The 400 was originally designed for the large ford cars.
The casting numbers is the key to Ident.
Get me casting numbers from the
Block (6015), Heads, Intake .
Also get me the Day of casting numbers.
They look like this * 7D25 *
I'll let you know then you get me that info.
Old Oct 10, 2004 | 07:50 PM
ranger429's Avatar
ranger429
How many valve cover bolt's are there? This will not tell you the exact year but we can tell you the cubic inch of the motor.
