Sponsored by: Auxito
Fog Light Question
Old Oct 10, 2004 | 11:04 AM
Dale Hess's Avatar
Dale Hess
Question Fog Light Question
I've got a 2000 XLT with fog lights. I'd like to change the wiring so that the fog lights are on without having to pull out the switch. And when I pull the switch out it would turn them off. Do any of you know if this is possible?
Old Oct 10, 2004 | 01:20 PM
AegisSailor's Avatar
AegisSailor
Well, the easiest way would be to find the relay that operates the lights, and replace it with a normaly closed type.
As installed now, you probably have a normally open type of relay, when you pull the switch on the dash, it applies power to the relay, closing it and powering up the lights. A normally closed type of relay will do the opposite, it will open when power is applied.
Old Oct 10, 2004 | 01:26 PM
Cuisinart's Avatar
Cuisinart
I wonder if this link might be what you are looking for?
Old Oct 10, 2004 | 04:35 PM
AzPete's Avatar
AzPete
I know that is the exact link I needed for my playing around. I actually have wired my fogs to run any time the key is on (use as DRL's) and my KC's to the original fog system. Yes, I used all the right relays and such to not overload the switches. Now, I will be able to turn on my 2-100 watt KC's when ever I "feel the need".
Az. Pete
