Changing Predator Programs
Old Oct 9, 2004 | 11:51 PM
rstokes's Avatar
rstokes
Question Changing Predator Programs
I just installed a Predator on my 04 F250 PSD for the first time yesterday. The instructions advise approximately six cold starts before the truck should train itself to the 65 hp economy performance mode. Have now completed this regimen and truck runs superb and now shifts smoothly. My question is; if I change to the lower hp towing mode, will I have to put the truck through the six cold start process again for it to re-learn the new Predator program?
Old Oct 10, 2004 | 12:55 AM
Maxium4x4's Avatar
Maxium4x4
Any time you reflash it takes a few cold starts. I usually warm my truck up before I reflash and I only get a couple of hard shifts the first day. I run the 100 setting most of the time and you should watch WOT after a reflash.
Other than that....have fun.....
Old Oct 10, 2004 | 04:11 PM
SierraClubS's Avatar
SierraClubS
what are cold starts?
Old Oct 10, 2004 | 05:24 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Sits over night or cools off enough to be a cold start.
At the North pole it would be like…1 hour
Old Oct 11, 2004 | 12:18 PM
SBV45's Avatar
SBV45
Here is a procedure for your trans to "learn":
1. Warm the engine and transmission to operating temperature.
2. Perform three series of upshifts at light, medium and heavy throttle (while driving with trans in D).
3. Perform three sets of gear engagements (N-R, N-D, D-R, R-D) with the brake pedal firmly depressed and waiting three seconds between each engagement with vehicle stopped.
Peform these steps once in normal mode and once in tow/haul.
Old Oct 11, 2004 | 01:20 PM
Hawkins's Avatar
Hawkins
Not True I live just North of North Pole and sometimes it would take two hours
Old Oct 11, 2004 | 02:17 PM
IB Tim's Avatar
IB Tim
You are up there just a bit
