Bronco II Ford Bronco II
86 Bronco2 - No Start
Old May 26, 2000 | 06:39 AM
gej@pgc's Avatar
gej@pgc
Please Help! Was running great...pulled into 7-11, shut off engine (2.9) and it has never run since...that was 37 days ago! Cranks fine but no spark. Replaced coil..no luck; replaced coil to dist. cap wire..no luck; replaced Ign. Mod...no luck. Checked for fuel...pumps running fine and fuel reaching engine...even pushed the "reset" on fuel relay just to be sure. Replaced Solinoid..no luck; replaced Ign. Switch...nothing! Pulled dist. and replaced stator (pick-up coil)...still no spark! Bronco has new cap, rotor, wires & plugs. I even pulled the EEC out of my neighbors 89 Bronco (he was not happy about this) and placed it in my 86...still no spark! Ran the codes on my EEC and the only code comming up was the TPS...replaced it just to be sure..still no spark. I even went so far as to pull the loom off the wiring harness and checked for broken/burnt wires...nothing. I have even gone so far as to check all fuseable links with my mulimeter...no problems. HELP!! I sure don't want to tow it to my ford dealer, but I'm running out of options. Have I missed anything?????
Old May 30, 2000 | 07:50 PM
nitro94's Avatar
nitro94
Check the computer ground circuts. Sometimes found on back of heads. Main grounds are the two smaller wires directly off the negitive battery cable. These are bad about connection problems. And they will cause a no spark condition.
Old Jun 17, 2000 | 04:21 PM
redbronco2's Avatar
redbronco2
Check your ignition switch.
Old Jun 26, 2000 | 05:19 PM
boodlum's Avatar
boodlum
Pulled dist. and replaced stator (pick-up coil)...still no spark...........Is this the little chip behind distributor?? cause that is what stopped my truck. luckily I didnt have to replace as much as you!!
Old Aug 4, 2000 | 03:53 PM
deleontow's Avatar
deleontow
Check and see if you have proper conections at the coil, maybe a bad coil or bad conection. Not much left that you have not changed. Check the power at the coil and ensure that you have voltage there.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old Nov 2, 2000 | 08:24 AM
gej@pgc's Avatar
gej@pgc
Thanks for all the help and sugestions. Found the problem was indeed electrical and turned out to be the wireing harness that leads to the ignition mod. on the dist. Seems this harness runs behind the engine and sits on lays on top of the transmission. The rubbing of this harness against the engine block and the transmission caused a wire to wear. This caused the ign. mod. to not receive power and therefor no spark.
Thanks again everyone.
Old Dec 27, 2000 | 10:37 PM
rsnii's Avatar
rsnii
Also check your timing chain hehehe ford is famous for running then not startin jumps time when you turn it off
Old Jan 5, 2001 | 10:59 PM
nosweat's Avatar
nosweat
Most common "no spark" situation is caused by defective T.F.I. Module (attached to the side of the distributor , 6 pin connecter ). If you remove the module they are easily tested with any ignition module tester.A "No Start" can also be caused by an open in the ground circuit. You should check the small ground wire connector at the battery (coming off the negative battery terminal and leading off into the wiring harness)You will see a small round black single pin connecter, usually very close to the battery (6 inches from neg. terminal)
Old Jan 9, 2001 | 12:39 PM
kootenay1's Avatar
kootenay1
Old Mar 26, 2003 | 03:07 PM
jefftbressler's Avatar
jefftbressler
had same problem and it did turn out to be the TFI...lot's of troubleshooting and replacing this that and the other before discovering the problem...
strokerfe
17
Apr 8, 2011 09:32 PM
bren_tx
Mar 8, 2010 03:17 PM
bfktwb4
Dec 1, 2009 07:26 PM
Xtreasurehunter
15
Mar 11, 2006 10:00 PM
theo
Feb 27, 2004 01:43 PM
