Dieing when cold
Old Oct 9, 2004 | 07:00 PM
stokdd's Avatar
stokdd
Dieing when cold
When my '70 F100 (360) is cold, I have to sit there and keep revving up the engine until it's warm or else it'll die. I realize that it's carb'd and that's normal, but I was wondering if there's an adjustment or something that'll keep it from dieing? A friend of mine's '74 F100 (240 straight 6) will drop the revs down very low, but it won't quite die.
Any ideas?
Old Oct 9, 2004 | 07:41 PM
sharkdance's Avatar
sharkdance
Is the choke working? If not, check the tube that runs down twards the manifold. Mine was disconnected and twisted off before I bought my truck. Guess they did it when they put headers on it.
If you live in a cold area you could always put a manual choke on it with a cable running inside the cab.
Or perhaps Im way off and its not choke related at all.
Sharkdance
Old Oct 9, 2004 | 10:37 PM
WillyB's Avatar
WillyB
Also, there should be an adjustable fast idle cam on the linkage that speeds the engine up when the choke is on. When starting a cold engine you should push the throttle to the floor to allow the choke and fast idle cam to engage, then release the throttle. Spin the starter and the engine should start, if not you can pump a shot of gas to help it along.
Once the engine has warmed up, you will have to bump the throttle to allow the cam to drop free for a normal idle.
Old Oct 10, 2004 | 12:21 PM
stokdd's Avatar
stokdd
There are two lines running down to the passenger side exhaust manifold. One is a hard line has a braided covering, the other is a vacuum line that connects into a hard line. The vacuum/hard line looks fine, but the tip of the other one is broke off (still being held in place by the braided covering). Might that be the cause?
Don't quite understand...before I started the truck this morning I pushed the throttle to the floor for a second. Truck started right up, but otherwise the same result. Is there a way to tell when the fast idle cam has engaged?
Old Oct 10, 2004 | 12:43 PM
WillyB's Avatar
WillyB
You can watch it as you move the linkage by hand - should be part of the accelerator linkage. What sort of carb do you have? Maybe we can find a picture.
The lines to and from your exhaust manifold provide warm air for the coil in the choke - there should be one (soft?) from the air horn that provides filtered air to a "stove" built into your exhaust manifold, and one (hard) that takes the heated air up to the choke housing. Internal passages in the carb draw this hot air through the coil in the choke and down into the intake manifold.
The idea is that as the engine warms up, the coil in the choke also warms up and opens the choke.
Old Oct 10, 2004 | 01:30 PM
stokdd's Avatar
stokdd
The carb has an Autolite plate on it.
Old Nov 26, 2004 | 03:15 PM
'71 f100's Avatar
'71 f100
stove's bottom pipe
I have the same problem. My 71 302 2bbl auto lite stalls after start. I have to give it gas for several minutes to allow it to warm up. I think I also suffer the same piping problem. I'll try to describe:
On the passenger side exaust manifold two 1/4 pipes run out of a bulge in the manifold (is that the stove?). One from the bottom to a rubber hose that connects to the top of the carb, running to the air intake, within the filter. The other pipe runs out the top of this bulge to the choke and has the cloth sheath around it. My bottom (bulge to air intake) pipe has broken off at the bulge. It probally happened when a spark plug was being pulled. It is really in the way of the plug closest to the passenger area. I tried to JB weld it back, then lock tite - both no good.
Is this the problem? How do I fix it?
Old Nov 26, 2004 | 09:03 PM
WillyB's Avatar
WillyB
71 F100 - yes that is a problem. The hose to the air cleaner is the cold air into the manifold heater, the other the warm air from the heater to the choke - it provides the heat that relaxes the coil in the choke housing. The cloth is an asbestos wrap to insulate and keep the air warm. Without this line being connected your choke will not work right.
The tube just pushes into the manifold so replacing it with some other tube is always an option. You can also change out the choke for a later model one that uses an electric heater - just connect the wire to the stator winding of your alternator.
