Problems
Old Oct 9, 2004 | 12:10 AM
mikewalsh1's Avatar
mikewalsh1
Problems
Within the last 3 weeks my early 99 PSD 6 sp. will start and run fine but blows a ton of white smoke. It will run till it gets to normal temperature than will just quit. slowly but it is like the cylendrs quit firing one at a time till it quits. I have to wait for it to cool to start again. Any Ideas?
Old Oct 9, 2004 | 01:02 AM
psdpower's Avatar
psdpower
Shot in the dark, how old is your air filter?
Old Oct 9, 2004 | 05:53 AM
jharvey3's Avatar
jharvey3
Sounds like you may have a couple of problems....the white smoke is unburnt fuel so you could have a glow plug issue, gpr not working, or bad gp's. The engine quitting sounds like the CPS has or is fixing to go south on ya. Pick a new one up at an International dealer for a lot less than Ford gets for them. Also check your valve cover wiring harness and the connectors on top of the valve cover make sure nothing is loose or burnt.
John
Old Oct 9, 2004 | 08:16 AM
Kwikkordead's Avatar
Kwikkordead
If it continues to blow a lot of smoke even when it's warmed up right before it conks out on you I think you have failed fuel injector o-rings.
Old Oct 9, 2004 | 09:25 AM
mikewalsh1's Avatar
mikewalsh1
problems
I guessed on the CMP and it didn't help I guess my next move is to get into the injectors.
Old Oct 9, 2004 | 10:42 AM
wheelzzs's Avatar
wheelzzs
are you sure that your intake isn't sucking water..........white smoke, temperatures hmmmmmmmmmmm you may be blowing water through your injectors
Old Oct 9, 2004 | 11:29 AM
fk1904's Avatar
fk1904
Mike, I am interested in knowing the cause of your problem. My truck is smoking and missing. Miss feels like one cylinder. Smoke is very intense and smells like unburnt diesel. I purchased re-built injectors and after about 2 hours of driving time the problem started. I also hear a popping sound from my exhaust somewhat rythmic.
kev03
Mar 5, 2014 07:28 PM
mwkobe
Aug 31, 2011 08:15 PM
bigbubba87
21
Jul 31, 2011 11:08 PM
Roy Morgan
General Diesel Discussion
Jul 26, 2010 12:24 AM
Dmandan
Sep 27, 2007 10:52 AM
