How will this sound?
. That wouldn't make people happy. Thanks for the info ramboss429 and 351M! I figured an auto takes away from the sound a bit, but it does do a little something if you are going about 35 and drop it into 2nd. Mine sounds like a semi with the second cat off doing this. I've done this a few times because I like the sound, but it's probably not great for the transmission or motor.
Also, a small block won't sound like a BB, atleast not a stock 302.Okay, so with a 460 351M, you'd say cherrybombs were pretty loud if it set off alarms? And ramboss429, you'd say that with cherrybombs it wasn't loud at all, I'm hoping for not very loud. I've got neighbors and just driving something that's super loud isn't great today, it was better in the 60s when almost every car had a little rumble to them. I like loud, but don't want my truck that loud. With straight pipe and cats, way too wussy. Now, with one cat on, that's almost the sound I want. It could be louder, but then I might be pushing it.
So do you guys think I should just forget the cherrybomb and leave the first cat intact and then just weld on the hollowed second one? I was thinking I'd get some popping with the cherrybomb, but seems like with my 302 it's only a glorified muffler.
I'm still wondering what kind of can muffler will be mildly loud and keep any clatter noise the motor makes?????
And that air hose on the cat, do they just slip on, I see some sort of rusty clamp on mine???
Then I could just weld it back on. It's a pain to get to where the hose leads to the pump or I'd just pull it right out attached to the cat.
So, I'm guessing that with open headers, it's louder. If you put in some restrictive piping, say 2.25", the pipe will muffle it a bit? Not much, LOL,
One more thing, my truck doesn't smell right now with the first cat. Will it smell without it on? I don't want to be going down the road and have people smelling the exhaust fumes because I don't like to be behind a stinky truck. I'm guessing again here, but if it's running right then it won't smell much right?
Thanks again, your info helps!
Kyle
Anyways, tried the one delta 40 (with cats ON) and it had wussy sound.
Now, I'm gonna go all out and true dual it with Delta 40's and no cats.
Will that sound sweet?
Also, someone mentioned that w/out cats there could be emmision smell... Is it real bad?
You will smell "bad" without the cat's. How bad depends on the engine. You'll have unburned hydrocarbons and whatnot all running around in your exhaust..instead of taken care of it in the cat's.
Just some insight. Also...D-Flow's are EXPENSIVE. Glasspacks are 18 dollars for a Dynomax Thrust Magnum 2.25 in/2.25 out 24" glasspack. 18...vs 80+. I'd try a glasspack first and see if you like it. If you didn't like the D-flow before, you're probably not going to like it now.
