87 Bronco II Rear ABS Problem
Rabs
I have an 87 BII and had trouble with the RABS in and out of warranty and finally gave up on it. That was 90,000 miles ago and I have never had an incident where I wshed it had worked. I did get tired of the RABS light and unplugged the connector from the top of the RABS module in the kick panel behind the driver and the problem(light) went away. I'm not recommending that you do this, I'm just telling you what I did. The inspection stations in VA won't pass you if the light is on, sooo......
Good luck!
Good luck!
Originally Posted by 87 XLT
OOPS, just reread your last post & I see that your E-brake does turn on the red brake light. Closest thing I can find to your RABS light on/off/on is RABS light comes on & stays on. With ABS light on apply E-brake & red light should stay on. Release E-brake & ground the test connector if NO CODES are flashed "disconnect module" & check for 11 to 13 volts between pin one & ground with KOEO. No voltage, check the 20 amp RABS fuse. If voltage is good check connection of the master cylinder fluid level switch. Then remove the connector from the master cylinder switch & connect a jumper between the two purple & white wires of the connector. KOEO & both brake lights should be on.
I rooted through my parts bin (we had a parts BII) and found another control module...I unplugged the old one (key off) and stuck in the other one.
This cleared the steady light ....for a few minutes.... I drove around and the RABS light came on... only this time it wasn't on all the time... It was randomly going on and off... (on for 2 minutes off for 30 seconds...on for 30 seconds off for 3 minutes etc...)
I tried the Diagnostics with the engine still on and the light on... still no flash codes...ARGH!
I turned the key on several different times to find sometimes the light was on and other times it was off... When it was off and I grounded the diagnostic connector the RABS light would come on steadily... Ungrounding would merely turn off the light... no DTC...
I tried your procedure above... With the RABS light on applying the E Brake brought on the "brake" light but when released the brake light would go out and still there was no code ... grounding the connector did't change the RABS light and ungrounding didin't change anything either....
I checked voltage at pin 1 we're 13-14 range (eng off-eng on).
I checked the connector at the master cylinder... one of the three pins has the tension foot broken off...
I shorted the two purple and white together and got the RABS light and the Brake light on...
I crimped the connector a little to try and insure contact with the M/C switch...but can't tell that it is making contact...wiggling the connector doesn't change the light...It is steady...
As a last resort...I'm going to look at Radio shack for a small connector insert to make sure the contact is good....
Any more ideas?
Again thanks for the help!
At this point I would really like to have a look at a couple of technical service bulletins. See items 53 & 224 at this link: www.alldata.com/TSB/20/87202533.html I presume thase are tips for solving hardcore problems like yours. Two ways to see these bulletins are to stop by your "friendly neighborhood Ford dealer" & take a look -i've solved a couple of problems by doing this- or join alldata for 25 bucks.
Bronco-2 might have the best solution for this.
Originally Posted by dave milster
I'll give these a whirl tonight or tomorrow morning and post another thread...
The ABS was intended for the less than cautious driver who really shouldn't be driving to begin with at speeds over 20mph... So when they panic and slam on and "hold" the brakes the car still has some steering...
I can also think of several times where the ABS has prevented me from stopping when I wanted to just LOCK-EM at slower speeds...
Thanks,
Dave
Thanks,
Dave
1987 and 1988 RABS Oddities
Greetings,
Worked at Ford from 1983 to 1991
Totally familiar with your issues, the 87-88 Bronco II"s are different, it is a black /yellow wire. by the module in the door in front of the back seat, I've seen your problem several times, it usually strats out with thinks are fine when you start it up back out of the drive and then about 5 feet in drive the light comes on, No codes. The 87 and 88 do not turn on the brake lamp with low fluid only the RABS light, and to make it even harder the light comes on when the fluid level is at the parting line on the resevoir. But thqt is the min mark on 87 & 88 take off the cap and the float is touching the bottom of the resevoir, Top off the fluid and see. That fixes all the ones I seen do that, they won't ouput codes if the fluid level is low on all RABS.
Greetings,
Totally familiar with your issues, the 87-88 Bronco II"s are different, it is a black /yellow wire. by the module that is in the door in front of the back seat you ground to test. I've seen your problem several times, it usually starts out with things bein fine when you start it up back out of the drive and then about 5 feet in drive the light comes on, No codes. The 87 and 88 do not turn on the brake lamp with low fluid only the RABS light, and to make it even harder the light comes on when the fluid level is at the parting line on the resevoir. But that is the min mark on 87 & 88 take off the cap and check the float is touching the bottom of the resevoir, Top off the fluid and see. That fixes all the ones I seen do that, they won't ouput codes if the fluid level is low on all RABS 1 trucks.
RayHell
09-27-2003 04:50 PM
