Sponsored by: Innova
CD Player Dims Lights?
Old Oct 14, 2004 | 07:34 AM
Ben Alston's Avatar
Ben Alston
well it help me all my lights would dim then i hooked up the strike cap and only the dome light dims now and my battery is weak
Old Oct 14, 2004 | 08:48 AM
MemOrex's Avatar
MemOrex
Theres NO way to keep lights from completely not dimming. Hell, do they not dim when you use power windows??
No Battery to chassis? What about the negative that goes right to it?
Old Oct 14, 2004 | 05:02 PM
RomerB2's Avatar
RomerB2
On mine the battery goes to block, and then the block goes to chassis, and also my lights don't dim when I roll up or down my elec. windows. The strike cap, is not at all going to help with dimming of any kind, all they do is intense the bass, make it "tighter".
Old Oct 15, 2004 | 07:48 PM
blwilli's Avatar
blwilli
i hate to tell you this, but a capacitor is NOT a band aid for sub standard wiring. no matter how good your wiring is, you will drop voltage at idle (from about 14.4 to 13.6) and remember that the battery is only 12. this is the case with a completely stock vehicle...and has to do with the centrifugal speed of the generalor (alternator) when you slow to idle, the output drops. Amplifiers are designed to run bes at 14.4 volts...due to the slow discharge characteristics of these types of capacitors, your voltage will be held closer to 14.4VDC at idle.
Old Oct 15, 2004 | 10:34 PM
Guitar_Stitch's Avatar
Guitar_Stitch
There is an Engine to Chassis ground, but there should be a Batt to Chassis as well.The stock grounding has all been cut and replaced. Currently the Battery negative terminates to the Alternator Mounting Bracket. That is the ONLY ground wire from the Battery. Every other ground ties to the Engine block.
MBBFord
2004 - 2008 F150
Nov 12, 2014 04:14 AM
78'fordtruckguy
Jan 19, 2009 08:15 PM
nlemerise
20
Oct 26, 2007 08:02 PM
IPACA9
Mar 6, 2006 07:50 AM
Bobinater33
Dec 1, 2005 09:33 PM
