fuel woes
Old Oct 6, 2004 | 10:02 PM
fordtough4x4's Avatar
fordtough4x4
Cool fuel woes
i have a 2001 250 superduty 7.3 L. leaks fuel into antifreeze. had dealer fix- under warranty. they said they replaced all inj. sleeves ford part #f4tz-9f538-a , seal-fuel inj part #xc3z-9229-ab , trans kit part #bg3020 (what's this?) ,coolant #vc-4-a , add cool #vc-8 (?) , cap asy-press #f6dz-8100-a. also oil leak diag pinpoint & replace high pressure o-ring at head per 00040404. from what i can see,from looking,bolts from fuel line missing & fuel line tightened. does not look like any other bolts were touched. cost me $100.00 ded. is there any way to tell if i was taken & if so what can i do? high pressure o-ring replaced twice in past, same dealer. comments appreciated thanks
Old Oct 8, 2004 | 08:09 AM
fordtough4x4
i had another mechanic look at my truck. he said the valve cover on the passenger side was never removed, therefor those injectors were not replaced.the dirt & grime on top of my engine possibly got inside when the other cover was removed, hard to tell if it was. if you want possible trouble or half the job done GO TO MEDVED SERVICE DEPT. castle rock colo.
Dan V
69
Mar 27, 2014 08:03 AM
160SOAR
Dec 3, 2011 09:23 PM
Raven855
Jan 21, 2011 08:04 AM
5.0 Junkie
27
Mar 14, 2010 02:24 PM
Roadgrinder
63
May 6, 2009 01:53 PM
