i got a new after mkt set from barnette's machine shop 757.625.6878. bottom line with heads ready to install $500. these are stronger than the originals. one alt bolt will not match up but i have put 4000 miles on it, seem to not miss that bolt. you can get a larger bolt and reem out the alt bracket to accept the larger bolt. also the rear pax side ground strap bolt will not match either. i just re-routed the strap to the intake plenum, 4000 miles so far.
