I have started my rebuild, I got my heads in today and my stroker kit. The heads are World Roush 200 heads and the stroker kit is a 347 Eagle kit. The Keith Black pistons that came with the kit have a valve relief but I do have some concern that the valves may hit the pistons. I was planning on decking the block .025, does anyone know haw far the piston is from the top of the block at TDC. The cam I'm using is a Lunati 290/300 cam with 232/242 @.050 with a lift of 544/560 and I'm using a set of Crane roller rockers 1.7.
If it makes any difference the valves are 2.02/1.60. Thanks
