SEFI on a '72
Old Oct 5, 2004 | 10:56 PM
rjh4758's Avatar
rjh4758
SEFI on a '72
I would like to know if I can put SEFI on my current 302 or will I have to swap the whole motor? Being a non-EGR motor affect anything? And will I have to add MASS air to it since it still has the original cam? Looking to gain some extra MPG's and better cold weather starting. Thanks for any help.
Old Oct 6, 2004 | 05:39 AM
EPNCSU2006's Avatar
EPNCSU2006
It would be a lot of wiring, but it can be done. You may as well go with mass air too while you are swapping, and then you wouldn't have to worry about the cam. You'll need intake manifold, distributor, fuel pump, high pressure fuel line to and from the tank, injectors, all engine sensors, wiring harness, computer, etc. Not having EGR might cause the engine to run slightly lean at part throttle cruise.
Old Oct 6, 2004 | 04:10 PM
Kemicalburns's Avatar
Kemicalburns
www.fordfuelinjection.com
Old Oct 7, 2004 | 07:37 AM
rjh4758's Avatar
rjh4758
Thanks for the info. Just wondering if anyone else has tried a conversion like this?
Old Oct 7, 2004 | 08:51 AM
Kemicalburns
have you tried a basic search on yahoo or google. im sure its been done. also look into www.rustys4x4.com they specialize in oldschool bronco's like yours and im positive they could give you the info you need as well.
