location of water seperator
open the hood, there is a plastic cover in the middle of the engine that says "powerstroke" on it. it is behind that cover and under it a little there is a fined cover on it(under that fined cover is your fuel filter) towards the bottom of that canister on the passenger side is the water release valve
Here's a tip: Open the lever for 1/2 second. After closing it, do down under the truck and look up to find the now dripping/ wet metal tube that leads from the water drain and drops directly on the frame of your truck. Go to the parts store and get some 1/4 inch fuel line and a hose clamp. Push the fuel line onto the metal line and route the fuel line away from the hot exhaust manifold and down to a handy location below the frame. Cut the fuel line at the appropriate length and install the clamp. Now when you drain the filter bowl it's a simple matter of placing a container under the end of the hose and opening the valve.
I use a piece of pnuematic tubing that slips over the end of the metal tube easiliy and I drain at every oil change. Get tubing long enough to securely reach well into a glass mayonaise jar. It will fill 2/3 full. I store the deisel fuel for cleaner on small projects. Also really works well as bug and tar remover on the kick panels.
