Sponsored by: Kumho
Leaf springs stabilizer
Old Oct 5, 2004 | 10:04 PM
76fordtruck's Avatar
76fordtruck
Today, I was looking at my truck and i noticed that some sort of leaf stabilizer on both sides of the truck had snapped off. what are these?
the bar goes from a mount in the middle of the leaf spring, to where the leaf and the frame meet.
the mounts on the frame and leaf just sheared off, so.......do i get them from a junkyard.
please help, and thanks in advance.
Old Oct 5, 2004 | 10:14 PM
ivanribic's Avatar
ivanribic
I'm having a hard time visualizing this. Is it on the back (not sure if you have leaf springs up front)?
Old Oct 5, 2004 | 10:22 PM
76fordtruck
it is on the rear, they kind of remind me of some sort of sway bar. they attach at the mount on the front of the rear leaf-springs, and then have a pivot joint that attatches to the center of the leaf spring. my dad says it keeps the rear-end in place when you gas it.
Old Oct 5, 2004 | 10:39 PM
ivanribic's Avatar
ivanribic
It almost sounds like you're describing an overload spring or helper spring but I'm not sure. Do you have a swaybar also? All my truck has (and most I've worked on) is the sway bar and shock mounts. I've never seen anything else attached to the leaf spring hangers.
Old Oct 5, 2004 | 11:04 PM
76fordtruck
parralell to the leaf springs, and is not a spring. it is a hardened metal rod that pivots as the truck suspension moves.
Old Oct 5, 2004 | 11:16 PM
76fordtruck
Old Oct 5, 2004 | 11:25 PM
f250rangerexplorer's Avatar
f250rangerexplorer
a stabilizer bar or torsion rod?
Drive It Like You Stole It!!!
Old Oct 5, 2004 | 11:30 PM
76fordtruck
torsion rod sounds right.........paralell to leafs, roughly 2 ft. long, 1 in. thick, bolts to leaf and frame?
Old Oct 5, 2004 | 11:51 PM
74fordtruck's Avatar
74fordtruck
get a pic on here bro. i'll look at it tomarrow if you want, but i dont know the suspension on your truck better than you do. later
Old Oct 6, 2004 | 09:24 AM
beartracks's Avatar
beartracks
Sounds like a "Shure Trac" bar. Made to act as traction and anti wrap up aid.
Old Oct 6, 2004 | 12:20 PM
76fordtruck
based on what 74fordtruck said at school today, i'm led to believe that it is an anti-wrap device. what i'm still wondering about, is am i ok driving with them broken. are they stock or not?
Old Oct 6, 2004 | 03:25 PM
73Custom's Avatar
73Custom
I think Beartracks is right... Sounds like an aftermarket traction bar that mounts to the top of the spring. Like this one... They are not stock - you could remove/repair/replace them.
Marty
Old Oct 6, 2004 | 05:01 PM
76fordtruck
your link didnt work but imagine this is what you found. Turns out it is a traction bar, and luckily i dont need them, but i am going to get new ones.
i finally got a pic online, but then i found this one, but i thought i would add my cryptic pic as well. Thats pretty rad that my truck can snap those things just from lightn' them up.
HkyswiM
Feb 16, 2012 05:10 AM
JM5034
Dec 11, 2008 06:26 PM
Welk49
May 22, 2008 05:47 AM
beemr
Jan 30, 2007 10:50 AM
WesternAuto17
1978 - 1996 Big Bronco
Oct 17, 2003 10:48 PM
