Tow what?
Old Oct 5, 2004 | 03:58 PM
SBV45's Avatar
SBV45
Tow what?
Yesterday, I gave my buddy a ride over to the garage near Canyon Lake. He was having his old Suburban worked on. There is a guy there with a Chevy 2500. Complaining about the problems with the sixth serpentine belt getting screwed up by a failing A/C belt. He looks at my F250 6.0 PSD and says I got two of those too. Got problems with the tranny! I say, "Really?" He says, "I tow equipment around. Darn things keep shifting up and down all the time in the hills." I say, "Do you put the trans in tow/haul mode? If you do, the trans has a separate program for towing and uses the engine for braking." He gives me a deer in the headlights look and says "Tow what? I just hook em up and go!" Well there is one of the sources of alleged Torqushift problems.
Old Oct 5, 2004 | 05:28 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Go figure...how in the heck did he get this far in life.....
Old Oct 5, 2004 | 10:29 PM
Jontx's Avatar
Jontx
The only problems I found in the Torqueshift was Ford reprograming it!!!
Old Oct 6, 2004 | 06:25 AM
IB Tim's Avatar
IB Tim
I am curious, what do you mean
Old Oct 6, 2004 | 08:51 AM
SBV45's Avatar
SBV45
I think he means with the flashes. i.e. tow/haul mode.
Old Oct 6, 2004 | 12:34 PM
Jontx's Avatar
Jontx
I mean the way T/H works after running change 8 was done.
I just got back to Texas yesterday after an 8 month tour around the Western US. Put 19,000 miles on the truck and fought the toe/ haul all the way. I pull a 12000 pound 5th wheel and you have to fight the xmission to brake and down shift. The Torque converter clutch releases every time you release the gas pedal. Then you need to do breaking to get the drag clutch to engage, then more hard braking to get it to downshift.
At legal speeds in Calif. (55) the TCC will not engage in T/H. Need to turn off t/H till lock up, then turn it back on. Also will not lock up in any gear but 6th .
When it was new none of this stuff happened as above, it all worked.
Engineers are so wonderful
Old Oct 6, 2004 | 12:55 PM
SBV45's Avatar
SBV45
I agree, jontx, the Ford software people really screwed up with some of those flashes. The sad part is, they won't do anything about it. I suppose you could DSB. I am not sure what can be done.
Old Oct 6, 2004 | 03:36 PM
jackofalltrades's Avatar
jackofalltrades
Reprogrammed transmission?
That's why I bought a 6spd. "I" control the gear I'm in!!! Last I looked, the transmission couldn't see what terrain I had under the tires, that traffic jam or hill ahead.
Some things I won't let a computer do for me.
Old Oct 6, 2004 | 03:58 PM
southernfordmanII's Avatar
southernfordmanII
I think Ford needs to put a allison tranny in it
$trokin60's Avatar
$trokin60
Aparently the TQ-shift is't all its cracked up to be read my post a few post down in the torque shift operation forum.
Old Oct 6, 2004 | 04:02 PM
$trokin60's Avatar
$trokin60
SBV45 some people see the ford SD, and dont realize that 2003 and later have the torque shift. He might have a superduty with a 7.3 and the E4OD/4R100 in it.
Old Oct 6, 2004 | 06:28 PM
Outdoors1's Avatar
Outdoors1
Lightbulb
And when you run into a guy like SBV45 talks about, he probably tows stuff a lot heavier than the truck is rated for and then complains when it breaks down.
Old Oct 7, 2004 | 09:16 AM
50jd60's Avatar
50jd60
T/H mode was good in mine except it would sometimes squeal the tires when down shifting into 1st gear, they reprogramed it and now it only downshifts 2 times, lost low gears downshifting
Old Oct 7, 2004 | 11:57 AM
IB Tim's Avatar
IB Tim
What year and build date is yours
Old Oct 7, 2004 | 02:09 PM
50jd60's Avatar
50jd60
Its an 03, with build date 4-28-03
