Cracked the block
Old Oct 5, 2004 | 11:23 AM
bigorange79's Avatar
bigorange79
Cracked the block
I just bought a 70 ford wagon with a 429 in it. Its a DOVE-a block with DOVE-c heads. While removing the engine I managed to crack the block through the threads of the lower bell housing bolt. Cracking off the ear down the center of the threads. I want to know if its possible to repair this and if the repair has been done before and what they used. I would think you could weld it on with nickel welding rod and it should hold up fine. Its not a real precision spot it just needs threads. Any ideas would be appreciated.
Old Oct 5, 2004 | 11:35 AM
fordtrkpuller's Avatar
fordtrkpuller
FTE *******
A good welder can fix that up easily. I have heard of welding these blocks on race engines in many different and more criticle areas with great success. If your a pro welder your all set, if not go and find one locally.
72bigredflatbed
51
Nov 30, 2018 11:42 PM
snknby123
Feb 3, 2015 08:54 AM
tbird250
Dec 26, 2010 04:42 PM
TMI
Jan 8, 2007 10:51 AM
chowitworkz
Sep 23, 2006 01:21 AM
