400 hesitation????
Old Oct 5, 2004 | 11:05 AM
Stumps78's Avatar
Stumps78
400 hesitation????
I have a 400 in my 78 super crew 4x4 I recently replaced the headers intake and carb took the heads to a local shop for pressure test and cleaning and resurfaceing. the new intake and carb is a Edelbrock. 600cfm I have a spot in the gas pedal where the truck wants to die? If I mash the pedal it hesitates then I let off the pedal and feather it, it then comes to life. Any ideas on what could be the problem? all vac lines are correct, timing is good ,msd ignition is fine. HELP!!!!!
Old Oct 5, 2004 | 01:11 PM
beartracks's Avatar
beartracks
I'd start with the carb accelerator pump. It should start to feed gas as soon as the linkage moves. There are also different squirters and cams available to tune it.
Old Oct 5, 2004 | 02:56 PM
Stumps78's Avatar
Stumps78
400 hesitation
Thanks I will start there....
Old Oct 6, 2004 | 12:17 AM
beeboy's Avatar
beeboy
also could be running too lean, or have a vacuum leak.
Buyerz
Nov 9, 2015 11:18 AM
liljerry
1978 - 1996 Big Bronco
Feb 28, 2013 09:34 PM
Cory281
Dec 30, 2012 02:05 PM
brokersteve
22
Sep 10, 2012 02:36 PM
greatbargins10
Dec 23, 2011 09:38 AM
