Right Carb?
Old Dec 22, 2011 | 11:42 PM
greatbargins10's Avatar
greatbargins10
Right Carb?
I have an autolite c8zf-g on my 78 F150 custom 400cid. I was pretty sure it wasn't original & started checking it out. seems to be off of a mustang. it runs great at idle but hesitates & is hard to start when the fuel tank is low or it's warm. anybody know if this carb is not good for this application? or maybe a weak fuel pump?
Old Dec 23, 2011 | 08:06 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Hesitation off idle is usually the accelerator pump. Here is some info on the carbs: https://www.ford-trucks.com/forums/1...eral-info.html
Old Dec 23, 2011 | 09:38 AM
HIO Silver's Avatar
HIO Silver
The Z in the PN denotes a Mustang but carb tags can come and go. What is important is whether it is an Autolite 2100 (2bbl) or a 4100 (4bbl). Both versions are really good carbs and SUPER simple to rebuild.
If it's a 4100, look on the right side of the carb body for 1.08 or 1.12. The former is around 480 cfm and the latter is 600 cfm.
2x.. a bog is usually the accelerator pump. There is an arm to the pump that can be relocated to the inboard hole if it needs a stronger shot. If i's maxed out, you might as well throw a $25 rebuild kit at it.
roadrash63
Aug 3, 2014 11:18 PM
JRB65
21
Mar 5, 2013 10:52 PM
jeff gammon
16
Feb 29, 2012 07:36 PM
koihito
Jul 5, 2005 09:17 AM
desperado_18_2000
Nov 11, 2002 12:26 PM
