Electrical problem?
Old Oct 5, 2004 | 09:33 AM
stokdd's Avatar
stokdd
Electrical problem?
Whenever the brake is pressed in, the right blinker comes on. It doesn't flash, it's constant. Both blinkers work otherwise. Any clues?
Old Oct 5, 2004 | 11:12 AM
1081's Avatar
1081
I would check the grounds at your taillights, especially the one on the same side as the blinker. It is possible that there is a bad ground at the socket and it is going back the blinker line until it finds a ground.
