Bronco II Ford Bronco II
auto tranny ?????
Old Aug 11, 2001 | 12:02 PM
88iline6's Avatar
88iline6
auto tranny ?????
got a question about fluid. helping a bud put a new tranny in but put the wrong type fluid in the torque converter.do we have to get it out and if so how???
Old Aug 11, 2001 | 09:32 PM
thelonerangerxlt's Avatar
thelonerangerxlt
auto tranny ?????
Hard to say without knowing what tranny and what type fluid, but generally speaking, it should be OK if only the torque converter was filled. If you used Type F instead of Mercon/Dexron, that is OK. You should change the fluid soon after a rebuild, anyway.
Old Aug 12, 2001 | 12:59 PM
TowerMaster's Avatar
TowerMaster
auto tranny ?????
I always thought that Dextron was interchangable with Type F... You just cant use Type F in a Dextron Tranny...
Old Aug 12, 2001 | 08:50 PM
86Broncho2gal's Avatar
86Broncho2gal
auto tranny ?????
We had a rebuild done on our F150 awhile back, and we were told to use Dexron or whatever that stuff is. It used to have FTF in it. We had bought a new torque converter, and he told us to always use the same type...everytime. You should probably take out the plug and drain the thing. We sat our old one over a bucket and unplugged it. There's also a way to turn it over (upside down) and the fluid will eventually drain out. Good luck!!
Old Aug 14, 2001 | 12:26 AM
charlez's Avatar
charlez
auto tranny ?????
wahlturfcare
37
Jun 18, 2016 01:44 PM
winginit
May 15, 2015 03:46 PM
scottskingdom
Dec 17, 2003 12:00 PM
Beast12
Oil & Lubrication
May 11, 2003 07:35 PM
dzk007
Aerostar
Apr 13, 2002 11:13 AM
