Transmissions to avoid?
Old Oct 4, 2004 | 08:52 PM
funnyboy's Avatar
funnyboy
I've had several '70's and '80's pick ups and Broncos over the past 20 years with 4speeds and C6s that were rock solid. I am now thinking of buying an early '90's through '96 F250 4x4 xcab.
My question is this: I recall conversations a little while ago of an overdrive tranny made between 87-96 that most here thought was pretty weak. This truck will be used for plowing, will occasionally tow a 24' boat, and will see a good deal of highway use.
Was the C6 made thru '96?
Is there a tranny I should avoid?
Thanks,
John
Old Oct 5, 2004 | 08:44 PM
c_rossman's Avatar
c_rossman
Late 80's early 90's E4OD I would avoid unless rebuilt, The C6 was available thru atleast 94 in Econoline vans and 2wd F250's with the 300 or 351w. All in all I like my ZF 5speed in my 93 f250. Rock Solid!
Old Oct 5, 2004 | 11:20 PM
SquareWheels's Avatar
SquareWheels
I bought a '96 F250 4x4 5.8 with a 3 sp. C6 in it this spring. I was led to belive that this tranny was available in only some of the trucks with a gvwr of 8600 or higher. I looked up my numbers, and this is the stock tranny. It is an ex oilfield truck and it may have been a special order, but they do exist. I've owned 2 other fords previous with the A4OD and didn't have the best of luck, but then it could be driving? I have never heard anything negative about the C6 and highly recomending the search for this. best of luck.
Old Oct 6, 2004 | 09:36 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
I was told by a transmission rebuilder that the early E4OD issues have mostly been resolved. Not all of them were bad, if you got a good one and kept the fluid clean fluid it is probably still good today. The bad ones broke a long time ago. No transmission is reliable without clean fluid.
I don't think I would use an A4OD for towing and plowing but I have never owned one.
C6 is rock solid but you have no overdrive. 4.10 gear would be great for what you want but C6, 4.10 and interstate travel would not be a good match.
F250 or 350 with a 460 or diesel with 4.10 limited slip and overdrive is what you probably want. I don't recommend a truck like that for daily transportation if you drive many miles, the fuel costs will eat your lunch.
Old Oct 6, 2004 | 08:32 PM
funnyboy's Avatar
funnyboy
So, it doens't really sound as if the E4OD or the A4OD have very many fans. It appear as if I should stay with a 351/C6 combo.
Thanks for the replies
Old Oct 6, 2004 | 10:02 PM
Kista20's Avatar
Kista20
if you want a manual tranny you can't beat the zf's. It has a granny first gear and it also has overdrive in 5th.
Old Oct 8, 2004 | 04:53 PM
jamiesan's Avatar
jamiesan
DITTO, ZFs are TOUGH. Autos to avoid are any type of AOD, except the 4R70W.
as you know the c-6's are pretty stout as well.
Old Oct 8, 2004 | 06:44 PM
Wagster's Avatar
Wagster
I have an 89 F150 with a 351 and the C6. Bullitproof trans. They are pretty rare in 1/2 tons. I think many that have them were special ordered. Only downside is no O/D which hurts mileage.
Old Oct 8, 2004 | 06:57 PM
c_rossman's Avatar
c_rossman
AOD isnt that bad of a tranny if it is maintained, they were never offered behind the windsor anyways.
Old Oct 8, 2004 | 10:36 PM
Roushians's Avatar
Roushians
What manual tranny's are found in later year (96-97) F-250's??
I'm looking (probably will never find a good one in my area though) F-250 4x4 HD Reg Cab 7.3L TD, unsure about what to look for in a tough tranny.
Old Oct 9, 2004 | 06:46 AM
c_rossman's Avatar
c_rossman
ZF's, In 1999 they went to a ZF 6speed, even better!
Old Oct 12, 2004 | 12:47 AM
t_dickie's Avatar
t_dickie
I have never came across a 91 and newer with the AOD. Older than that still did, but don't know about the 4x4's. If you want an automatic, definitely get the E4OD. They are a good tranny if maintained (I'm hard on mine but take care of it, and no problems yet). Ford stuck them behind the 7.3, so they must have some strengh. I've pulled some decent loads and it did it without hesitation. And if it does fly apart, once they are rebuilt, their indestructible. A C6 wouldn't be good for pulling yet still have some driveability. But I still suggest a standard would be a better bet. So it depends on what you want really.
