over-charging problem
Old Oct 6, 2004 | 09:11 PM
pops_91710's Avatar
pops_91710
Originally Posted by 89broncobob
I just bought a && F-100 2 weel drive with 4 speed and 302. I put a tester on it and found it to be over charging bad . Then while it was running i took the batt cable off and it ran a whole lot better. I didnt drive it just running in the drive way. Do you think it is the alt or the voltage regulator. The regulator is on the front fire wall next to the radator. I paid 150.00 for it and it has no rust out side just the floor boards , So i guess i got a good deal.
I am not sure you really have a problem at all. Why do you think it's "overcharging bad"? An alternator only puts out the amount of volts required to top off the battey as needed. It can't put out any more than that. A regulator only switches current to the battery as required. If the regulator sticks then it can put back too much to the battery, and thus overcharge it.
You didn't mention how you tested it, what numbers you got, and whether or not you were reading amps with an ammeter, or volts with a volt meter.
Give us some more details.
Old Oct 7, 2004 | 06:35 AM
89broncobob's Avatar
89broncobob
it was with a load and volt meter and the volts went to 16 to 17 volts.
Old Oct 7, 2004 | 09:07 AM
beartracks's Avatar
beartracks
If the regulator is bad you can overcharge. Also if you lose diodes in the alternator you can send AC voltage to the battery which is not good. It will also show up as high voltage on a DC scale.
Old Oct 7, 2004 | 10:08 AM
Purely Ford's Avatar
Purely Ford
I think beartracks has a good point. I have had the diodes in an alternator act like nothing more than resistors and the simptoms seem similar to what have been described.
Old Oct 7, 2004 | 10:12 AM
89broncobob
It is a strange thing , Over charging but draining the batt at the same time , I guess from over charging and then it running good with the batt disconnected. How ever i think the last time i did that to show a friend it burnt the coil or some thing out couse now i have no spark . So YES i will hurt things by removing the batt cables while its running.
Old Oct 8, 2004 | 10:13 AM
89broncobob
Ok, now after taking the Batt cable off while it was running , It died and now it will not start . It will crank but no spark . I changed the coil and tested to see if i was getting power to the coil and i am . What would be the next in the line . Voltage regulator maybe. ? Thanks for all the help in advance.
Old Oct 9, 2004 | 09:53 AM
pops_91710's Avatar
pops_91710
Voltage regulator? What's that got to do with starting the engine? the pick-up coil is bad, that's my guess.
Old Oct 9, 2004 | 11:04 AM
89broncobob
changed the modual and no she starts again , However its still over charging to about 17 to 18 volts so i will change voltage reg in a few
Old Oct 9, 2004 | 11:44 AM
fordmando's Avatar
fordmando
I had a similar problem, it ended up being a bad ground between the body and the battery. I added a ground strap, problem went away.
Old Oct 9, 2004 | 03:09 PM
89broncobob
changed regulator and now charging fine. BUT no gauges work... Just got the truck to work on as a hobby and its a mess.
Old Oct 9, 2004 | 06:58 PM
Mil1ion's Avatar
Mil1ion
Except for the ammeter, the gauges run off the Instrument cluster voltage regular, which is mounted to the rear of the cluster (like a 9 volt battery)
Yes, you have to removed the cluster to get at it
Old Oct 9, 2004 | 07:00 PM
89broncobob
Ok , I have no cluster lights and no gauges that work just the ALT light works.
Old Oct 9, 2004 | 07:24 PM
  #28
razell's Avatar
razell
did the gauges/cluster work b4 you tried the trick with the batt. cable & fried the coil? those relays are pretty fragile creatures.
Mad tiki
15
Dec 14, 2015 10:08 AM
Onus
Jan 29, 2012 03:36 PM
HeeHaw78
Dec 20, 2010 03:01 AM
Sillbeer
Electrical Systems/Wiring
25
Dec 7, 2010 08:11 AM
fiittllc
Aug 18, 2008 11:07 AM
