Surging and Bucking
Old Oct 4, 2004 | 12:42 PM
oldbuck's Avatar
oldbuck
Surging and Bucking
1993 5.0L e4od 185k. when truck is cold runs with no problems, when up to operating temp truck bucks and surges between 25 and 35 mph. Over 35mph runs smooth. 0-25 you can hear the engine surging but you can not feel it. new tps, and 02 sensor recently. I am at a loss on this one.
Old Oct 4, 2004 | 09:04 PM
Jmackenroth's Avatar
Jmackenroth
mine is an 88 fi50 w 5.0. I am gonna change the Fuel pressure regulator tomorrow. and the 02 if needed, so please if you find anything else out let me know.
Old Oct 5, 2004 | 09:33 AM
fefarms's Avatar
fefarms
It sounds like you may be experiencing E40D "shudder". Try pushing the overdrive off button and see if it smooths out. Or put the gear selector into second gear. These transmissions are noted for a "stick-slip" behavior on the torque converter lock-up clutch, especially on high-miles vehicles. This sometimes gets better with a fluid change.
Old Oct 5, 2004 | 07:49 PM
Jmackenroth
it was the fuel pressure regulator thanks for the help
Old Oct 6, 2004 | 06:54 AM
oldbuck's Avatar
oldbuck
fluid
I just had the fluid changed last night, lets see if anything changes.
