tires
Old Oct 3, 2004 | 07:16 PM
thomas24's Avatar
thomas24
Question tires
Ok guys,
I got a 93 f150 2 wheel drive with stock 235's and got to put better tread for the winter whats the largest size I can go to without changing anything? Next yr. I'm gonna raise front to level it and go with 31's. But right now I need more tread for winter.
Old Oct 3, 2004 | 08:15 PM
aikigod's Avatar
aikigod
31x10.5" will fit on a stock 2wd truck without any rubbing. On a 4wd truck, you can put on 32x11.5" with no/minimal rubbing (might rub during full wheel lock). I also believe that if you put that levelling kit in your front, you'll be able to stuff in 32" tires in as well.
Old Oct 3, 2004 | 09:03 PM
sandrat's Avatar
sandrat
Negative on that. My 31x10.50s rub on my 4x4 with a 2" lift in the front. It's only on a hard left turn, so I don't really worry about it, but just so you know... I'd go ahead w/ the 31's, just realize they might rub a small bit.
Old Oct 3, 2004 | 09:29 PM
andym's Avatar
andym
The 31 x 10.5's on my stock height 4x4 rub at full lock as well.
Old Oct 3, 2004 | 09:42 PM
Rebel2302's Avatar
Rebel2302
33!!!!
I have a 89 Ford F150 2WD, I put on a set of Superlift 2inch coils to level out the front, and I was able to put on procomps Xterrains 33x12.50R15's. I have to take it slow on the dips and when I crank the steering wheel all the way it rubs but not that bad. It doesnt matter what tire you go up to, it will eventually rub on the radius arms. I am planning on getting Fabtechs 8inch Long Travel kit, in about 2-3 weeks. The fabtech radius arms are set farther in, so it eliminates the rubbing when you turn!.
Old Oct 3, 2004 | 09:45 PM
aikigod's Avatar
aikigod
Really? I just put on a set of 31" three weeks ago, and have yet to have them rub at full lock. Hmmm, I guess I stand corrected...
Old Oct 4, 2004 | 12:08 PM
hsfbfan's Avatar
hsfbfan
265/75/15's were a factory option on the 4x4's that year. This is a 31x10.50. Shouldn't rub.
Old Oct 4, 2004 | 05:19 PM
joerocket's Avatar
joerocket
My 95 4X4 Off Road has 31X10.5 (third set) and I have never had any rubbing problems either. One question though I have duel shocks up front but have yet to see another F150 with them. I know the Bronco's had them but not any one fiddys'. Anyone know about this?
Appoligize for any thread jacking that might occure.
JOE
Old Oct 4, 2004 | 05:47 PM
Toolman1973's Avatar
Toolman1973
I have a 92 4x4 and have 33's on them and they rub just alittle on hard turns....
Smiles
Toolman
Old Oct 4, 2004 | 06:17 PM
couleeman's Avatar
couleeman
I run a 33x10.5 on my 4x4 and they rub on tight corners, but normal driving they will never come close. (2+" lift)
Old Oct 4, 2004 | 06:27 PM
thomas24's Avatar
thomas24
tnx everyone
