92 302 engine trouble
Old Oct 3, 2004 | 05:48 PM
92fordblack's Avatar
92fordblack
Hello, I'm new to the forum, but it's been helpful thus far. My problem relates to the running condition of my motor. At idle, it will run, sputter, almost die out and come back, all within 5 seconds, and repeat. When driving, as long as you have the pedal pushed in a little bit, it will run fine. but at cruising the engine does that and the transmission jumps. I took it to the ford dealer and to another place and no one could tell me what's wrong. I took the battery off for 3.5 hours and replaced it, and it runs ok now with it doing it's crap every so often. I've already replaced the fuel filter and cleaned the egr valve. Any idea's? thanks, Scott
Old Oct 3, 2004 | 06:23 PM
MustangGT221's Avatar
MustangGT221
Check the computer codes...and check fuel pressure
Old Oct 14, 2004 | 09:02 AM
92fordblack
Checked the codes. Wound up being the Throttle position sensor. Thanks again.
Old Oct 14, 2004 | 11:18 PM
Dennie McNeely's Avatar
Dennie McNeely
I have a 92 F150 with a 302 5 speed. Mine did the same thing. I replaced the EGR vavle and EGR sensor. Also replaced the MAP sensor. The beast runs great now and I get better gas mileage
