Bronco II Ford Bronco II
Power windows
Old Nov 16, 2001 | 02:46 PM
rey64's Avatar
rey64
Power windows
Hi, Can anyone tell me where the harness that carries the Voltage for the power windows in my 87 Bronco II is connected to. Mine is inoperative so I tested and notice that there is no power to the switch, if I put power from any other source directly to the switch it will work. This means that I have a cable or harness open and I want to get it fix.Where does the harness get the power from?
Old Nov 19, 2001 | 09:01 AM
Bronc02Ken_'s Avatar
Bronc02Ken_
Power windows
Does your other window work and if so which one is broke? Power comes in through the drivers door as you are able (at least on my 87 model) to control the passenger window from the drivers door. I am pretty sure that the p/w and door locks have their own fuse and circuit but I don't have a wiring diagram here at work to look at. Anyway there is a good chance you have already checked these items so I would start tracing the wire back from the fuse box. I suspect it will either go out to under the hood (towards the battery) but would diffently chech the connection through the fire wall. Those connections where it passes from interior to under the hood can get corroded and cause problems. When I get a chance to look at a wiring diagram and will try to give you more areas to check. Ken
Old Nov 22, 2001 | 09:58 AM
Avanti's Avatar
Avanti
Power windows
