Changing fuel filter
Old Oct 2, 2004 | 01:38 AM
ssKable's Avatar
ssKable
How do you change the fuel filter on a 99 f150 5.4l v8? Is it easy? where is it located, what tools are needed etc... any links to pages with tech articles including pics would be a plus if the fuel filter is in an odd location. I have helped a friend change his on an older chevy pickup so I think I could probably handle it if its not too difficult. Thanks.
Old Oct 3, 2004 | 10:17 PM
FOMOCO1965's Avatar
FOMOCO1965
Im Prety Sure It Is On The Driver Side Frame Rail, Rite Under The Driver Side Door. Its No To Bad To Get To, Im Prety Sure If Its From Snap On Its The Red Quick Disconnect Fuel Line Tool But I Think You Could Find The Same Tool At A Local Parts Store For Alot Cheaper. Just Make Sure You Clean Any Dirt Or Other Debree Out Of Both Sides Of The Connection At The Fuel Filter, I Use Brake Or Intake Cleaner. Put The Tool All The Way In Fitting Till It Bottoms Out And Then Pull The Line Out From The Fuel Filter. You Will Also Need Either A 8mm Or 10mm Wrench Or Socket To Take The Filter Off. Hope This Helps
