parking brake troubles...help
I'm the original owner of the above vehicle. The problem i'm having is with the parking brake not working. At around the 40,000 mile mark the parking brake pedal started to travel down to the floor without locking the rear wheels. I have always used the parking brake from day one when i park.
When i went to the dealership with my problem they told me that the left backing plate was rusted/corroded and needed to be replaced. My extended warranty did not cover this because "corrosion" is exempt.
The repair was quoted at $600. I blew a nut when i heard that. Long story short....the dealership paid 80% and i paid 20% or $125.
The rear axle had to be pulled and the differential cover had to be removed to do all this, so there was some labor involved with this. Please follow me with this because it gets better.
So, i get the truck back and the parking brake works pretty good again. This was done on august 4th 2004. Well, guess what doesn't work again???? So i go back to the dealership and they confirm that the pedal goes to the floor again and the brake is not holding the rear wheels.
Two hours later they call me and tell me that the right side backing plate is corroded and needs to be replaced like the other side was 2 months earlier.
I proceed to blow another nut and go off on the service department. I don't park in water or live near an ocean. My truck is pampered and yet they tell me that corrosion is the problem. They give me that 'caught in the headlights deer look'.
Has anyone heard of this or experienced this with any ford product? I can not believe that a 2 year old truck should have these issues. WTH!!!
-hooD
