Sponsored by: Kumho
spring problems
Old Oct 2, 2004 | 12:49 AM
plod's Avatar
plod
Talking spring problems
my 1990 f250 4x4 seems to sit lower than most that i have seen around,I noticed there only about 2" between the front leaf and the bump stop is this normal.it has a wierd sring code on the door "636" what ever that means.Will 1 ton springs fit as i carry alot of weight and hopefuly give it some more hieght.
Old Oct 3, 2004 | 09:45 AM
fishmanndotcom's Avatar
fishmanndotcom
yes 1 ton springs will fit but doubtful they will give any height. you might look into getting a small suspension lift if you want some extra height
-cutts-
Old Oct 4, 2004 | 10:22 PM
Hounddog1's Avatar
Hounddog1
Just to add to your research, I have a '93 f250 4x4 SC long box that had a problem with a sagging front end.
I installed new 1 ton leaf springs up front and the front end shot up 4.5 ". To compensate for the additional height, I installed factory 4" 1 ton rear lift blocks to help level out the truck.
Chances are you may experience a "lift" by adding 1 ton springs
renegade_75
Mar 13, 2013 02:50 PM
StrokiN&SmokiN
Aug 11, 2008 11:52 AM
John Kusanovich
1997 - 2003 F150
Nov 21, 2004 08:55 AM
