Help ! My Expy is driving erractically !!!
Old Oct 1, 2004 | 11:46 PM
bodinejcs's Avatar
bodinejcs
Hello Fellow Ford Members ,
My 99 Expy is pulling off the road under medium accelleration . Lets say your going 50 mph and you gas it to passing gear , the truck wants to pull off the road , its could be dangerous if you did not know . My steering wheel is off a tad too. This seem to happen after I pulled a junk car out the bushes in the back forty . I pulled it from the trailer hitch though and i was center to the vehicle . Most guys say I have bent rear control arm or a bad bushing . I cehecked it out and everything seems tight and its not noisy when hitting bumbs . Anybody heard of this happening before ? I am getting grossed out driving this thing and need to fix it . Truck has 130,000 and has always tracked straight with a perfectly centered steering wheel ? Any Suggestions ??
Thanks ,
Bodine
Old Oct 2, 2004 | 10:33 AM
chaznolan's Avatar
chaznolan
Have you brought the truck for a 4 wheel alignment?
Sound's to me like you skewed the alignement when pulling that junker out.
Find a good shop with a computerized laser alignment and throw it up on the rack.
I bet ya your way off.
Dont forget to rotate the ole tires after alignment.
Old Oct 3, 2004 | 10:24 AM
bodinejcs's Avatar
bodinejcs
4-Wheel Alignment ???
Hello ,
Thankls for your reply , I have called my local alignment shop , and yes that is what to do , but , They told me there is no adjustment in the rear and that
is what is doing it , not the front end , so I am sure I have a bent or bad bushing in the rear , just wanted to see if anybody experieneced this . I havemade my appointment at the align shop , so we will see . Thanks for your help kind sir .
Jeff
Old Oct 3, 2004 | 08:38 PM
ToolTime's Avatar
ToolTime
I dont know if our Expy's have floater rear ends, but if they do, you could also have a broken axle. Keep in mind that this is probable worse case senario...
Old Oct 3, 2004 | 08:40 PM
ToolTime's Avatar
ToolTime
Talking
OOps, the word is probably! I just got home from work, brain fade!
Old Oct 3, 2004 | 09:06 PM
saltzy's Avatar
saltzy
What makes you think that, specifically? Is it that you see/hear/feel something broken, or that it's just *that* obvious when you drive it?
