Oil Change Procedures?
Old Oct 2, 2004 | 06:21 PM
troutnut1's Avatar
troutnut1
Historically I have changed at 3,000. Repeated oil analysis at Blackstone labs shows everything is doing very well. They always comment that I could go a lot longer between changes. So this time I have gone 5000 and will see what they say. They'll probably still say I could go longer. And I'm sure they are right, but as Dan mentions...oil is alot cheaper than engines. I should also add that these are EASY miles in rural Montana. 60 relatively flat miles to work and back at 70 mph with no stops. Chevron Delo 400 oil looked almost new on the dipstick @ 4,000. New filters everytime of course. My truck now has 202,722 miles on it and it runs and tests out great.
Old Oct 2, 2004 | 06:35 PM
'961506's Avatar
'961506
I use delvac in my 2000 f-250 7.3, and I change it every 50000, even after that it isn't very dirty.
Old Oct 2, 2004 | 09:22 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by BigRed350
Having changed my own oil exclusively since I've owned my truck, I can tell you that the actual amount used to refill the crankcase to full varies by as much as 2 or 3 quarts. I'm not exactly sure where it "hides", but I've used as little as 12 quarts total and as much as 15 to bring it back up to full. .................
That is interesting, my truck takes about 14 quarts every time. Over 100,000 miles so far and I change my oil every 4500-5000 miles. I think may not be getting all the old oil out of your truck, do you sometimes park the nose of the truck downhill?
Old Oct 2, 2004 | 09:41 PM
RickyBR's Avatar
RickyBR
I hope that was a typo!
Old Oct 2, 2004 | 10:52 PM
tobetaxfree's Avatar
tobetaxfree
I have also picked up some great tips here, including Quadzilla's gallon ziplock bag under the filter. I do break the filter free and then punch the hole. I also take a quart of fresh oil and pour it in the engine after the initial drain, and "rinse" the bottom of the drain pan out. Probably just psychologically comforting, but I see some dark oil coming out. I also started to do oil analysis from Blackstone Labs, and with 210,000 miles on my truck, I want no more than 3000 on an oil change.
Old Oct 2, 2004 | 11:21 PM
'961506's Avatar
'961506
Um yea.... sorry make that 5000, I wish there were an oil that was barely dirty after 50k...lol
Old Oct 3, 2004 | 06:21 AM
jharvey3's Avatar
jharvey3
Man it's almost broken in
John
Old Oct 3, 2004 | 07:18 AM
BigRed350's Avatar
BigRed350
No, same level position everytime in my driveway. The first time I noticed a difference I thought maybe the pan wasn't draining all the way, since then I have watched this phenomonon very closely and still have no explaination! My thoughts are that maybe it's sometimes hiding in the oil cooler and for whatever reason, other times it drains?
Old Oct 3, 2004 | 08:08 AM
slc10844's Avatar
slc10844
The high pressure oil pump reservoir tank has about a quart of oil that doesn't drain into the crankcase. I don't normally suck the oil out of the reservoir, but I think next oil change I will just to see if the oil looks any cleaner after start up. After the last oil change, the oil seemed to have a black tint.
