Aftermarket Products
Sponsored by: Worksport
Good rust stopper?
Old Oct 1, 2004 | 03:31 PM
Daijin's Avatar
Daijin
Good rust stopper?
I am restoring a 73 Bronco. I have some rust in the floorboards and bought a "rust stopper" at my local Napa. They said it worked well and when I wire brushed the surface rust off and brushed this stuff on it turned the remaining pits of rust black. Does anyone know if this will work well or do I need to buy something like por-15. Thank you.
Old Oct 1, 2004 | 04:59 PM
MatthewC's Avatar
MatthewC
Personally, I would use both just to make sure.
-Matt
Old Oct 1, 2004 | 07:56 PM
Samsonitesamsonite's Avatar
Samsonitesamsonite
por-15 is great stuff
Old Oct 2, 2004 | 12:07 AM
2003 6.0's Avatar
2003 6.0
I'll second that
Old Oct 2, 2004 | 07:29 AM
red mist one's Avatar
red mist one
3rd it here....POR is great stuff. Just follow the directions exactly. It dries hard as a rock.
Old Oct 3, 2004 | 01:27 AM
Daijin's Avatar
Daijin
I have heard nothing bad about Por. I am just curious...is it the ONLY great stuff? Hopefully napa didn't steer me wrong.
Old Oct 3, 2004 | 09:32 PM
daggerNC's Avatar
daggerNC
POR 15 is very good - I've used it. Note that it is UV sensitive meaning it will break down without a protective covering. I just saw that Eastwood company now has their own version of permanent rust conversion chemical treatment - and it is UV resistant. I'm going to try that version next time around.
dagger
Old Oct 10, 2004 | 10:57 PM
Tony G's Avatar
Tony G
Por 15 is good, but your surfaces have to be prepared as said and although they say it can be painted over rust, painting my ladder rack after they had weathered for 2 years, the por 15 didn't do the job. I also had some peeling of it on my floorboards that I noticed when I went in for follow up repairs 2 years later. (I had only done parts of the floorboards that I had replacement panels for at the time) I used to advocate por15 also and I think it's still a good product, by this last time I put on "rust bullet" It's a similar product, but can be layered, doesn't need as much preperation, and is cheper to buy.
The rust conversion stuff doesn't work in the same way as por15 or rustbullet, but it still works. These two are sealing paints and create a hard surface that is difficult for air or water to penetrate. Go to rust bullets website where they show some tests done on sample metal peices.
TonyG
Old Oct 29, 2004 | 09:01 PM
richierich45's Avatar
richierich45
Check out Zerorust at www.zerorust.com.
