Pops out of 4wd?
Pops out of 4wd?
My 86 BII pops out of 4wd after driving around for a little while. It doesn't make any noises, the 4x4 light just turns off and the traction goes away. If you drive along holding it in 4wd, all is well. What would cause this, and how do I fix it? It has manual hubs/transfer case. Thanks!
Rich
Rich
Pops out of 4wd?
yes there is an adjustment mine did the same thing after i replaced the transfer case it requires alot more info than i can tell you here if your a do it yourselfer go get a haynes repair manual and it will show you the correct way to put it back into adjustment doesnt take much really but it is a pain when its out of wack like that
