Owner Notification Programs / Recalls 2000 Explorer
Old Oct 1, 2004 | 01:37 PM
mbmech157's Avatar
mbmech157
Does anyone have any information on ONP and Recalls for a 2000 explorer, specifically the timing chain guides (01M01). If anyone has a letter from Ford, could you possibly scan it or copy its contents onto this thread. Thanks in advance. Mech in N.J.
Old Oct 1, 2004 | 03:01 PM
lardman's Avatar
lardman
It's for MY 97-8 not 2000
<TABLE cellPadding=2 width="96%"><TBODY><TR><TD>OWNER NOTIFICATION PROGRAM
01M01
</TD><TD></TD><TD>All 1997 and 1998 Model Year Explorer and Mountaineer Vehicles built with 4.0L Single Overhead Cam Engine - Additional Coverage Program for Front Cam Chain Guide Assembly
</TD></TR></TBODY></TABLE>
<HR class=BLUE><TABLE cellSpacing=0 cellPadding=0 width="96%"><COLGROUP><COL vAlign=top align=left><COL vAlign=top align=right><TBODY><TR><TD align=middle colSpan=2></TD></TR><TR><TD>Ford Motor Company
P.O. Box 1904
Dearborn, Michigan 48121
1-800-392-3673
www.ownerconnection.com
</TD><TD>
</TD></TR></TBODY></TABLE><TABLE width="96%"><TBODY><TR><TD align=right>July 2001</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 width="96%"><TBODY><TR vAlign=top><TD width="20%">TO:</TD><TD>All Ford and Lincoln Mercury Dealers</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 width="96%"><TBODY><TR vAlign=top><TD width="20%">SUBJECT:</TD><TD>Owner Notification Program 01M01 Supplement #2: Revised Technical Instructions and New Labor Operations (See Attachment II and III)</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 width="96%"><TBODY><TR vAlign=top><TD width="20%">RE:</TD><TD>Owner Notification Program 01M01: All 1997 and 1998 Model Year Explorer and Mountaineer Vehicles built with 4.0L Single Overhead Cam Engine - Additional Coverage Program for Front Cam Chain Guide Assembly</TD></TR></TBODY></TABLE>
REASON FOR THIS SUPPLEMENT
Original Instructions: At the time of publication, engine oil pressure test was used to identify engine bearing damage related to cam chain guide failures. Based on extensive testing of returned engines, we have learned that cam chain guide failures do not cause bearing damage. In addition, the oil pressure specification listed in the original bulletin and in the Workshop Manual was listed incorrectly and is being corrected.
Revised Instructions: On engines with severe cam chain guide damage, the revised instructions require visual inspection of the cam and cam followers for damage caused by lack of lubrication. On engines that are running rough, the cylinder leak-down test will still be used to identify bent valves. NOTE: Evaluation of returned engines will continue. We will continue using the green 01M01 Engine Tag. It will be revised to reflect the new service procedure. This tag must be attached to each returned engine.
New Labor Operations: The Labor Operations listed in Attachment II have been completely revised. Effective immediately, these labor operations must be used when submitting a claim. PROGRAM TERMS
This additional coverage program will be in effect for 7 years from vehicle warranty start date or 100,000 miles, whichever occurs first. VEHICLES COVERED BY THIS PROGRAM
All 1997 and 1998 model year Explorer and Mountaineer vehicles with 4.0L Single Overhead Cam (SOHC) engines built at the Louisville Assembly Plant from July 29, 1996 through October 20, 1998 and at the St. Louis Assembly Plant from May 29, 1996 through September 18, 1998. REASON FOR PROVIDING ADDITIONAL COVERAGE
On some of the affected vehicles, the front cam chain guide assembly may wear or break and cause excessive cam chain noise that does not go away after five minutes of engine operation. SERVICE ACTION
If the cam chain guide assembly is worn or broken, install a new cam chain guide assembly. If it has broken and fragments have entered the engine oil pan, clean the block of all debris, replace the engine oil pick-up and filter assembly, and install new oil and filter. ATTACHMENTS
  • Attachment I: Administrative Information
  • Attachment II: Labor Allowances and Parts Ordering Information
  • Attachment III: Technical Information
  • Attachment IV: Q & A Sheet
  • Owner Notification Letter
QUESTIONS?
Claims Information:...................................... ..............1-800-423-8851
Other (Dealer Only) Program Questions:.......................1-800-325-5621
jdadamsjr
2011 - 2019 Explorer
Feb 25, 2017 08:30 PM
johndeerefarmer
Dec 22, 2016 03:10 PM
DeeDubz
Aug 24, 2015 12:58 PM
rlross20
Jun 5, 2002 01:19 AM
