Radiator cap???
Old Oct 1, 2004 | 11:50 AM
Rick Oliver's Avatar
Rick Oliver
Radiator cap???
This may be the stupidest question ever, but...
Where the heck is the radiator cap on a 1997 7.3L F250? I'm used to cars, where the radiator cap is typically on the top of the radiator. But there ain't nothing on top of the F250 radiator except what appears to be a factory-installed plastic cover attached by about 8 bolts.
I'm trying to test the SCA level, and the test strip instructions say I can't test from the reservoir, only from the radiator. I'd also like to be able to add coolant when the need arises.
I'm completely stumped. Do I have to remove all those bolts and remove the plastic cover?
Old Oct 1, 2004 | 02:36 PM
wlihntr's Avatar
wlihntr
the cap on the plastic reservoir is it. that would also be where you add coolant, conditioner and test it...it is a little confusing
