1966 - 1977 Early Broncos
EB 9" Info
Old Oct 1, 2004 | 06:18 AM
JeremyH's Avatar
JeremyH
EB 9" Info
Hello, I dont post much in this section (mostly in the offroad forum) but I have a few questions about an EB 9" that I have found (I have searched). It is on a '71 chassis with a 302 (I believe), Dana 20 and what looks to be a 30 up front (I see no ball joints).
So here is some info I have obtained from the 9:
it is about 59" WMS-WMS, the drum measures about 11.25" in diameter and I found the following numbers stamped near the pinion:
C5AW 4668A
Now according to this website:
http://www.gearheadracing.com/Refere...FordDiffer.htm
it has fairly stout pinion bearings, but doesnt give much more info.
This is what was on the diff tag:
EM-E1
507HC605
Can anyone give me any info on this axle?
Thanks,
Jeremy
Old Oct 1, 2004 | 05:38 PM
JeremyH's Avatar
JeremyH
anyone?
Old Oct 2, 2004 | 05:51 PM
RCrawler's Avatar
RCrawler
The numbers you give from the tag don't seem to go anywhere in my cross reference list What I can tell you is that it is a big bearing housing, judging by 11" brakes.
Factory gearing with a V8 was 3.50 standard or 4.11 optional. I can't tell you whether it should have limited slip or not.
Pretty standard housing although not as desirable and stout as the 77 triangulated housing.
Jason
Old Oct 2, 2004 | 09:53 PM
JeremyH's Avatar
JeremyH
Where are you plugging in numbers? A website?
I might just need to pull the shafts and count the splines....
Thanks for the info BTW.
Old Oct 2, 2004 | 10:10 PM
RCrawler's Avatar
RCrawler
I have a list compiled of the common EB axle codes and #'s. And I double checked a few places on the internet.
BTW, I should have added that all Broncos originally came with 28 spline axles. But upgrading to 31 or 35 spline axles is common. Its a good idea to pull an axle and count the splines.
Your welcome
Jason
Old Oct 2, 2004 | 10:22 PM
JeremyH's Avatar
JeremyH
Hummm.....so thicker shafts, thinnner bearings?
Old Oct 3, 2004 | 01:48 PM
RCrawler's Avatar
RCrawler
The 28 spline shafts neck down to the splines. The 31's stay the same diameter. The bearings are the same size. I believe this is true with the 35 spline shafts as well. The weakness in a 28 is where the diameter is reduced and at the smaller splines (from torque)
Jason
Old Oct 3, 2004 | 04:36 PM
JeremyH's Avatar
JeremyH
Jason
Thanks! I'll look for the reduction when I pull it apart to check everything out.
