map sensor voltage?
Old Jan 8, 2005 | 09:55 PM
fefarms's Avatar
fefarms
It can run, but not well. The ECM has a "failure mode effects management" algorithm.
If it decides the MAP output is worthless, it will try to use the TPS voltage and PIP derived RPM to infer an approximate engine load and vehicle altitude and thus an amount of fuel to inject. This is a "limp home mode", so don't expect too much.
Sigrtn is a dedicated "virtual ground" back to the PCM. The idea is to isolate the relatively weak sensor inputs from all the ground noise caused by spark plugs, fuel injectors, alternators, etc. Attaching this wire to the engine block would be a bad idea; similar in nature and effect to the 60HZ hum heard from the amplifier of low-budget bar bands.
mikeheckler
1997 - 2003 F150
Sep 17, 2015 11:38 AM
fenix1
Electrical Systems/Wiring
Jun 8, 2013 09:31 PM
Tony R
6.4L Power Stroke Diesel
Mar 1, 2013 06:46 PM
acc7484
Aug 11, 2005 10:22 AM
RangerRuss
1983 - 2012 Ranger & B-Series
15
May 22, 2003 04:50 PM
