Door Ajar light stuck
Old Sep 30, 2004 | 08:47 PM
fnsump's Avatar
fnsump
The dome light and the warning light on my dash that says "door ajar"- is on constantly and I have made sure over and over and over and over that all the doors are secure. I would assume that I have an electriucl snafu somewhere.
Any suggestions at where I should start ?????
Old Sep 30, 2004 | 10:11 PM
1081's Avatar
1081
I know the back gate on my Mountaineer is very tempermental and I have to slam it a couple of time occasionally. I would say you probably have a bad switch. Are the interior lights staying on as well?
Old Sep 30, 2004 | 10:22 PM
oldgwth's Avatar
oldgwth
Have an 02 that had the same problem and for that year the door switch is in the latch. I assumed it was the drivers door and was given the following advice. Spray the latch and as much inside it as you can real good with WD-40. I did that opened and closed the door several times, resprayed a couple times and have not had the problem since. Sounds like a off the wall fix but it sure worked for me. I was told dust and dirt get in the latch and make the switch stick. Good luck.
Old Sep 30, 2004 | 11:42 PM
CobraXP's Avatar
CobraXP
Rangers are known for this also. Check out this thread - it should help:
Door Ajar Light
sbappleg8
1983 - 2012 Ranger & B-Series
15
Aug 2, 2017 11:45 AM
GTBksRule
Electrical Systems/Wiring
Apr 22, 2013 01:47 PM
socalarcade
Dec 12, 2010 05:17 PM
TampaDave
May 5, 2010 05:04 AM
bager
1997 - 2003 F150
Mar 17, 2004 06:55 PM
