carb vacuum problem
Old Sep 30, 2004 | 03:14 PM
81rangerF150's Avatar
81rangerF150
carb vacuum problem
hi guys,
I've figured out why my rebuild wasn't working: with the vacuum line hooked up from the base of the carb to the timing advance, the engine would choke out at mid throttle, but when i disconnect it (and don't plug it) it runs fine. Is there another air passage on the carb that might be blocked?
thanks
Old Sep 30, 2004 | 03:19 PM
Bear 45/70's Avatar
Bear 45/70
Vacuum advance line goes to carb never manifold unless there is a switch in between. Usually the ported vacuum fitting is on ths right(passenger) side of carb.
