Grind rust or neutralize
Old Sep 30, 2004 | 01:22 PM
fordxxx's Avatar
fordxxx
I am preparing my '72 F-100 to repaint the bottom half of the body. It has the original paint and there was surface rust at the bottom edges. I have sanded the paint away and wire brushed the rust areas and painted on RUSTMORT. Now these areas have turned black and supposedly the rust is neutralized. Can I now prime over them? Should I paint them with Rustoleum?
I was wanting to avoid grinding the rusty areas down to shiny metal because that would mean taking away alot of the surrounding metal.
Any ideas?
Thanks
Old Sep 30, 2004 | 02:52 PM
Mike W's Avatar
Mike W
You should be good to go with the primer.
Old Sep 30, 2004 | 06:24 PM
70f250's Avatar
70f250
Ya, does that rust neutrilizer work? I have some called Naval Jelly but havent used it yet, anyone had experience or tips on its use?
Old Sep 30, 2004 | 10:07 PM
Faithful Old Road Dog's Avatar
I never really liked Naval Jelly. Maybe I was just using iy wrong. I've used One Step in a rattle can.
Old Oct 1, 2004 | 11:52 AM
RyanF's Avatar
RyanF
Any ideas?
Thanks
Yes, providing the area is dry you should be ready for primer.I have primed over similar products such as RUSTMORe before and it worked fine.
Alcaeus
13
Feb 3, 2011 03:14 PM
headgoatroper
1947 and Older Ford Trucks
Mar 23, 2010 09:25 AM
rmilchman
22
Sep 17, 2009 08:46 PM
MustangGT221
Paint & Bodywork
Aug 16, 2005 09:25 AM
mshumack
Paint & Bodywork
Jul 22, 2002 06:23 PM
