engine removal
Old Sep 30, 2004 | 11:52 AM
71fordowner's Avatar
71fordowner
engine removal
hey guys just wondering if anyone can help me with an engine removal we have disconnected everything transmission bolts exhaust motor mounts pwr steering all that stuff and still cant get the motor to come loose any ideas that you could help me out with
thnx its a 71 f250 4x4
Old Sep 30, 2004 | 12:24 PM
Jimbare's Avatar
Jimbare
all alone in the world
if it is stuck in the bellhousing, check and make sure all the bolts are out. sometimes they get burried in grease. make sure the starter is off. raise the motor and put a little forward pressure on it, not too much now. use a prybar between the motor and bellhousing at the corners of the block, one on each side. just wiggle and pry carefully, it should come loose. sometimes after 25 or 30 years the alignment dowels will get rusty and seize in the bellhousing, just takes a little persuasion to get em out.
Old Sep 30, 2004 | 01:17 PM
71fordowner
thnx again going to try that we have removed all the bell housing bolts so were going to try and wiggle it out hopefully we can get it done well let you know fi we cant get her done
thnx
dale
