1978 - 1996 Big Bronco
Painting removable top?
Old Sep 30, 2004 | 01:09 AM
93BigBlackBronco's Avatar
93BigBlackBronco
What type of paint should I use for the removable top? I want to keep the texture but have a few small scratches needing repair. Color is black if that makes a difference.
Old Sep 30, 2004 | 01:45 AM
broncobillybob's Avatar
broncobillybob
Use a flat matte paint in several layers.
Old Sep 30, 2004 | 03:41 AM
93BigBlackBronco
Any special prep invloved? Sanding will remove texture. Will cleaning with wax and grease remover be adequate? What type of primer?
Old Sep 30, 2004 | 03:23 PM
Redbob's Avatar
Redbob
Paint it like you would any fibreglas object. See a paint supply store for details.
I don't think a primer is necessary unless it's been without any paint for a long time.
Flat paint is the ticket.
Old Oct 4, 2004 | 12:31 PM
ojosdestranger's Avatar
ojosdestranger
When I painted my 95 I had problems with the top.
The paint store told me to use either "Thinner or Reducer" to clean the top.
1. No need to sand. Just clean really good.
2. Apply Primer Sealer (seals the old paint and acts as an adhesive for the new paint)
3. Apply the Flat Base coat (about 1 quart)
It looked great until.....
I took it to the carwash (a few months later) and the areas below the side windows started to flake off (only a little). I guess I didn't clean those areas correctly.
So, be extra careful when you clean!
Stranger
Old Oct 4, 2004 | 08:02 PM
dcotton's Avatar
dcotton
My top has been painted with gloss black paint. Still has all of the texture and looks great. I wash mine with my power washer and have not had a single complaint yet.
I work at an R.V. dealership that has a bodyshop that paints fiberglass everyday, and as long as you prep it and make sure it is clean we then spray using regular auto paint.
My .02 cents worth.
D
Old Oct 5, 2004 | 09:04 AM
Wakeboarder141's Avatar
Wakeboarder141
My top was painted along with the rest of the truck with Dupont paint over a year ago and it still looks awesome.
Anderson80
Dec 15, 2016 07:28 PM
mmanos1
May 24, 2015 08:01 PM
Greenheadkiller
Appearance & Dress-Up
May 23, 2010 01:23 PM
94 XLT White/ Silver 302
Sep 30, 2004 01:37 AM
LEIGUY
Paint & Bodywork
Mar 11, 2004 06:08 PM
